il y a 3 ans 6 mois #460
par oxygen77
- Shapefiles Module: Better management of generic shapefiles, for instance those provided by NOAA.
- Weather Module: Add support for weather data provided by starpath.com (Ships Weather Reports). Add automatic download of Weather Stations reports.
- Alarms Module: New alarm if Internet connection becomes available.
- Charts Module: Add scale and projection data to SHOM geotif chart information.
- Marks Module: Mass import of POIs via paste is available again.
- Tracks Module: Add a Duplicate button. Allow editing of starting and ending date to extract a part of the track.
- AIS module: Add TCP/TCPA to targets dynamic data.
- NMEA module: Add possibility to add custom serial ports.
- Companion: Trial period is now 2h. Add Air and Water temperature.
- iOS: Add possibility to use a custom skin.
Bug fixes:
- Fix a crash when an activated route reaches the last POI.
- Improvement in the management of the period during which a POI cannot be moved (red circle).
- Fix route's tooltip disapearing too soon if NMEA is activated.
- The parameter TWS correction in grib configuration is now taken into account without needing to check/uncheck again the whole option.
- If Internet is not available at qtVlm launch it is no longer necessary to restart qtVlm if the connection is restored.
- Fix wind arrows in meteograms.
